Files from Briman
Admin
Files from Briman
Postby Admin » March 21st, 2008, 10:32 am
Here's a backup of files collected by Briman. Thanks Brian!
You do not have the required permissions to view the files attached to this post.
CMAZZ
Improvements to the Inexpensive Bike Lift
Postby CMAZZ » July 17th, 2011, 6:21 pm
Before I made the " Inexpensive bike lift , I studied it and made these improvements.
I cut the lift down to three feet long instead of four feet.
Instead of putting the 4 foot pipe in,I changed it to five feet to give me the extra leverage.
When I installed the galv. pipe flange on the board, instead of connecting the 5 ft. pipe to it , I put a 4 inch galv. nipple to the flange and connected a galv. ground joint union and then, connected the 5 ft. pipe to the ground joint union.
In doing this once the bike is lifted, the pipe handle can be removed so that it is not in your way to trip over.
Rgards,
CMAZZ
Da-Mack
Re: Files from Briman
Postby Da-Mack » July 17th, 2011, 8:50 pm
All kinds of great info and tips! Thanks for setting these out for us!
Users browsing this forum: Baidu [Spider] and 1 guest
