General Maintenance
General Maintenance
Postby Doc » June 9th, 2008, 4:06 pm
From the '04 owners manual
Capacities:
Fuel tank 4.5 gallons
Engine oil; without filter change 3.2 quarts, with filter change 3.6 quarts
Final gear oil 6.8-7.4 oz
Engine coolant 1.6 quarts
Spark plug gap .031-.035 inches
Replace spark plugs every 7,500 miles
Change oil every 3,500 miles
Engine coolant replace every two years
Brake fluid replace every two years.
Tire pressure; 29 psi front, 36 psi rear.
There's good info to be found at http://www.therusks.com under "How to Files".
Thanks for putting this together Sisco!
Users browsing this forum: No registered users and 1 guest
