General Maintenance
A file repository of the collective knowledge on everything VOL and C50
Forum rules
This area contains maintenance information as well as other reference material for the Suzuki Volusia VL 800 and Suzuki Boulevard C50 motorcycles. Items such as installation guides, owners manuals, and step by step tutorials can be found here. This area is read only, and only Administrators or Moderators can add files here. If you have a file that you would like to offer, please send a private message the Admin.
Doc
Site Admin
General Maintenance
Postby Doc » June 9th, 2008, 4:06 pm
From the '04 owners manual
Capacities:
Fuel tank 4.5 gallons
Engine oil; without filter change 3.2 quarts, with filter change 3.6 quarts
Final gear oil 6.8-7.4 oz
Engine coolant 1.6 quarts
Spark plug gap .031-.035 inches
Replace spark plugs every 7,500 miles
Change oil every 3,500 miles
Engine coolant replace every two years
Brake fluid replace every two years.
Tire pressure; 29 psi front, 36 psi rear.
There's good info to be found at http://www.therusks.com under "How to Files".
Thanks for putting this together Sisco!
Return to “The Library”
Users browsing this forum: Bing [Bot] and 2 guests
