03 Volusia engine noise
Having problems with your ride? Ask here.
MartyI
Postby MartyI » October 28th, 2011, 5:54 pm
Ref. my new member post from Sept 5.
Delete postReport this postEdit postReply with quote
Ok so now am getting frustrated. Put it back together with new cam chains, guides and tensioner arms. Did not replace the tensioners as they were free with no binding or sticking. Started it up and still had rattle. Took to a shop and had them listen. (brought it to them on a truck to minimize running) They said it sounded like valves, possibly a spring. Removed engine and took top end apart. Checked cam chains in case a tensioner was indeed binding, both were good and tight (not too tight though). Removed valve springs and valves. All valve springs look real good, none broken. Anybody have any ideas or suggestions of where to look now? Thanks. :x
MartyI
Re: 03 Volusia engine noise
Postby MartyI » October 28th, 2011, 5:56 pm
I did remove the cam chain adjusters and they moved freely.
leesbo55
Postby leesbo55 » October 14th, 2016, 11:02 am
rod bearings
Return to “I Need HELP!”
Users browsing this forum: Bing [Bot] and 2 guests
