03 volusia just bought. Cobra pipes Loses power between shifts sometimes cuts off when shifting into 1 st gear.
Paulg1031
Postby Paulg1031 » September 17th, 2015, 5:34 pm
03 Volusia cuts off sometimes shifting into first gear from neutral also runs rough and cuts out between shifting gears previous owner installed cobra pipes runs great with choke pulled halfway out I have adjusted the idol as high as I can without pulling the tank to get to carb
Doug_u.s.
Re: 03 volusia just bought. Cobra pipes Loses power between shifts sometimes cuts off when shifting into 1 st gear.
Postby Doug_u.s. » September 19th, 2015, 10:47 pm
probably have to rejet for the rough running.. I had an 03 and it usually smoothed out as it warmed up.. Check your kickstand switch to see if it might be causing the bike to die from neutral to 1st.. Good luck!! I wish I still had my silver and white 03 sometimes..
