2003 VL800
leesbo55
2003 VL800
Postby leesbo55 » October 14th, 2016, 11:10 am
wont run without choke (starter plunger) put in new pilot jet new valve seat and needle entire new starter plunger, new pilot screw. pilot screw adjustment no help, idle screw adjustment no help. cleaned and blew air through every port. start with choke out, push choke in it dies even zfter warmup.
Mrpic
Re: 2003 VL800
Postby Mrpic » February 2nd, 2017, 9:04 am
Do a search on the pair valve problem. Sounds like it might be the culprit
Users browsing this forum: MSNbot Media and 1 guest
