OIL & OIL FILTER?
rmagdn
OIL & OIL FILTER?
Postby rmagdn » February 21st, 2012, 10:11 am
I am attempting to changing my oil & oil filter for the very first time by myself. What kind of oil and oil filter should I get? ( I have a 2005 C50)
Da-Mack
Re: OIL & OIL FILTER?
Postby Da-Mack » February 21st, 2012, 8:03 pm
I have a 02 Volusia. I use the generic filter that MotorcycleSuperstore has and then I use 10W40 motorcycle oil. A lot of us as newbies found out that you don't use "car" motor oil as the additives in it will make your clutch slip. I usually use the standard stuff for motorcycles at Advanced Auto.
"I got vision and the rest of the world wears bifocals"
Lead an extraordinary life.
2002 Volusia...Red/Black...the red bikes are the fastest!
1975 Yamaha XS500
ron2k_1
Postby ron2k_1 » February 22nd, 2012, 12:03 am
Castrol Actevo 20w-50 motorcycle oil and suzuki filter on my end. The 20w-50 is better all year long for hotter climates than the 10_40.
Ron
Sent from my ThinkPad Tablet using Tapatalk
Time is a great teacher, but unfortunately it kills all its pupils
teddybearfrmhell
Postby teddybearfrmhell » February 22nd, 2012, 12:09 am
i use the fram filter from walmart.... and i use any 10w 40 NON friction reducing oil. look at the donut, the bottom rocker needs to be blank,. then you are good to go
DISCLAIMER: I would like to appologize in advance, if anything i say makes you cry, it was not my intention to get your panties in a bunch.
BottleCap
Postby BottleCap » February 22nd, 2012, 9:08 pm
It's super easy. If you can do a car, you can do a bike.
20w-50 Castrol Act-Evo and either a K&N or Hi-Flo filter.
Driving a 2005 C50 enginecycle.
Postby Doc » February 22nd, 2012, 9:30 pm
I like the K&N filters because of the nut welded on the end.. makes them easy to get on and off.
Oil.. well you're going to get a million opinions. Any good motorcycle oil for wet clutches (no friction modifiers) will work. Teddybear is right.. check that bottom rocker on the API logo. It should be empty. Putting an oil in with friction modifiers can cause clutch slippage and ruin your clutch.
avinaftel
Postby avinaftel » April 17th, 2012, 5:19 pm
Da-Mack wrote:I have a 02 Volusia. I use the generic filter that MotorcycleSuperstore has and then I use 10W40 motorcycle oil. A lot of us as newbies found out that you don't use "car" motor oil as the additives in it will make your clutch slip. I usually use the standard stuff for motorcycles at Advanced Auto.
When using car oil, just be sure not to get one that says its got cleansing detergents. It can play havoc with your gears. Otherwise its not an issue. Bike oils and filters are a myth created by the petroleum companies. Do the research. I run a regular car filter in my Vol, using an adapter I paid $10.00 for on-line. Its saved me plenty and its proven the car filters are far better than even K&N bike filters. As you can see, I'm adamant on this subject because I've done the research and am slightly pissed at having been fooled for so long. I pay close attention when anyone says special "for motorcycles". Most of the time its b******* to get us to pay higher prices.
ds_ohio
Postby ds_ohio » April 17th, 2012, 5:30 pm
K&N 138 and Shell Rotella T6 5W-40 full synthetic. I think I'm the Shell guinea pig here.
2009 Suzuki C50 Boulevard Special Edition Green/White
avinaftel
Postby avinaftel » April 17th, 2012, 5:53 pm
ds_ohio wrote:K&N 138 and Shell Rotella T6 5W-40 full synthetic. I think I'm the Shell guinea pig here.
Shell Rotella is the best. I'm using it too. I'm in Arizona so 5w is fine for the lower heat.
Postby Luvs2Play » April 17th, 2012, 8:09 pm
Rotella T6 and a Hi Flo filter.
