Black tough grease coming out of the rear hub
ron2k_1
Postby ron2k_1 » June 10th, 2012, 11:01 am
For the past two weeks, I've been having a black looking tar (really dry tough grease material) coming out of that area that divides the hub and the rear wheel.
I think I gonna grease the shaft today, so should I check anything else while the rear wheel is off?
Sent from my iPhone using Tapatalk
Time is a great teacher, but unfortunately it kills all its pupils
ron2k_1
Postby ron2k_1 » June 11th, 2012, 11:04 am
Well, thank goodness I decided to check that shaft yesterday. The oil seal gave in and there was fluid all over inside the shaft cover. As soon as I removed the gear hub, a brown murky gunk gushed down the shaft. Thank goodness I had a spear seal around. What a bear it was to remove the circlip too.
Question: does the fake swing arm has any use? I worked on the bike till really late at night and I messed up the threading on one of the screws that is behind the side cover. Does this swing arm present any support?
Ron
Re: Black tough grease coming out of the rear hub
Postby Elephant Rider » June 11th, 2012, 11:27 am
That fake swingarm is just for looks. You don't need it. I broke one of the bolts that holds it on, so it's only held on by 2 now. Oh well. It stays.
Postby Doc » June 11th, 2012, 11:32 am
Yup.. swingarm has no function.. there was a funny video clip that v0lrider did a while back that demonstrates this.. I'm going to try and dig that up.
