replacement part
littletoe
replacement part
Postby littletoe » January 23rd, 2013, 11:04 am
need to replace speedo on my 03 volusia-can anyone tell me if any other year model is compatible-thanks
Food,Sleep and toilet breaks are the enemy!!
Ratboy859
Re: replacement part
Postby Ratboy859 » January 24th, 2013, 10:32 am
Have you tried looking at the Parts Manual? Here is the link to get the Parts Manual http://www.volusiaowners.com/viewtopic.php?f=34&t=1107
Down load it and take a look. I tried to figure out what was going on and came up with crazy thoughts.
The K1/K2 uses 34120-41F00 or 34120-41F10 (Kilos and Miles/Kilos)
The K3/ZK3/K4/ZK4 don't list the speedometer.
The K5 uses a 34120-41FB0 or 34120-41FA0 (Miles/Kilo and Kilos)
The ZKR uses a 34120-41FC0 or 34120-41FDO (Kilos and Miles/Kilos)
The "K" designation represents the year....you should have a VL800K3 (2003 Model). It appears that most of these should be plug and play (depending on the miles/kilos indication). There are some other things to consider - Fuel Injection (or not) and model. I know that my C50T uses a white faced speedometer. A C50 will use a black face speedometer.
So, did I help you or confuse you more? :roll:
Edited (and more):
Try this web site http://www.onlinecyclepart.com/ they use the Suzuki Parts manual and show part numbers for the speedometers. I found the K3 to ZK4 data there. Even more confusion.....sorry
littletoe
Postby littletoe » January 24th, 2013, 2:33 pm
:lol: No confusion,bit of clarity-cheers for the assist Ratboy-found a few decent replacements but none where an 03 model. Couldn't find anything in the specs to say they aren't compatible.Thanks for the help.much appreciated [CHEERS] Hope your road ahead stays free from dickheads!
Ardhonu
Postby Ardhonu » March 10th, 2013, 5:02 am
Ratboy859 wrote:Have you tried looking at the Parts Manual? Here is the link to get the Parts Manual http://www.volusiaowners.com/viewtopic.php?f=34&t=1107
car parts are some other things to consider - Fuel Injection (or not) and model. I know that my C50T uses a white faced speedometer. A C50 will use a black face speedometer.
Edited (and more):
I purchase most parts from amazon or eBay. Have you tried these two sites?
